fuel/carby problem
This forum applies to Hondas.
shane
fuel/carby problem
Post by shane » Thu Jan 25, 2007 4:43 pm
my cb450 seems to have a fuel ploblem with the right hand carby. bike will start and idle, but right side very rough. have removed spark plug and tested compression, thats fine, but plug very black and strong fuel smell to it. have tried to set air/fuel mixture on carby, plus reset float level, but no change. can i purchase a carby kit to rebuild/overhaul carby?
or does any one have suggestions.
shane.
goals always achieved,but not always the right ones set.
podgy
needle height
Post by podgy » Thu Jan 25, 2007 6:10 pm
have u checked the needle height ?
there are carbie kits available in the usa ,do a searh on ebay for honda 450 should find what u want there
cheers podgy
shane
carby/fuel problems
Post by shane » Thu Jan 25, 2007 7:02 pm
no i haven't. i have this weekend off work and will pull carby off then to check. thankfully the previous owner also provided a manual with bike, so hopefully it will provide some info. will check the needle hieght saturday. thanks for ya input.
