Front end compatibility
This forum applies to XS 650 Yamahas.
Post by Prof » Wed May 23, 2012 10:41 am
Looks like these triple trees may be interchangeable as they all use the same bearing kit. NOt sure if length of headstem is the same though...
Steering Bearing - Seal Kit Yamaha FZ600 86-88, SRX600 86, TX500 73-75, TX650 70-76, TX750 73-74, XJ650 80-83, XJ750 81-83, XS500 76-78, XS650 70-83, XV750 Virago 81-83, XV920 Virago 82-83, XV920 Virago RH 81, XV920 Virago RJ 82, XZ550 82-83
Re: Front end compatibility
Post by ol_750 » Wed May 23, 2012 7:00 pm
Yes I just put an XV1100 triple tree into my XJ900/XJ750. They all apear to be 190 mm long & use the same bearings. 8)
The XV1100 swing arm bolts straight in also on my XJ & is longer.
JAC
Post by JAC » Thu May 24, 2012 5:04 am
Nice one. All I need is a comparable set for my chopper and it'll solve all my problems (bloody 550 rule)!
Post by ol_750 » Thu May 24, 2012 6:56 pm
Steering head bearing sizes posted on Scandalon.
ID OD HT
Upper: 25 x 47 x 15
Lower: 30 x 55 x 17
Yamaha XJ700N/NC/S/SC/XN/XS/XSC (85-86)
Yamaha XJ900RK (83), XJ900FN (85)
Yamaha XJ1100J (82)
Yamaha XV700 Virago (84-87)
Yamaha XV750 Virago (88-97)
Yamaha XV1000 Virago (84-85)
Yamaha XV1100 Virago (86-97)
ID OD HT
Upper: 25 x 48 x 13
Lower: 30 x 48 x 13
Yamaha XJ400 (80-85)
Yamaha XJ550H/J/K/RH/RJ/RK (81-83)
Yamaha XV500 (83) XV535 (87-99)
Yamaha XV535 (91-94), XV535H/N (89-90), XV535SE, XV535T/TC/U/A/ AC/EC/F/FC/G/GC/ SFC/SG/SGC/SH/SHC/SJ/SJC (87-97)
ID OD HT
Upper: 25 x 48 x 15.2
Lower: 30 x 48 x 15
Yamaha XJ650G/H//J/K (80-83), XJ650LH (81), XJ650LJ/LK/RJ (82-83)
Yamaha XJ750J/K/MK/RH/RJ/RK (81-83)
Yamaha XV750H/J/K/MK (81-83), XV750SE (82)
Yamaha XV920J/K/MK (82-83), XV920RH/RJ (81-83)
Yamaha XV1000K/L Virago (83-84)
That covers the stem fitting into the bearings, but what about the height?
The real nice thing about yamaha whether intentional or otherwise is that the steering head tube is the same length on most if not all the XV/XJ line.
Measured length on XJ750K, and XV700L: 190 mm
The following list of lower triple tree mounts will all interchange.
XJ Lower triple tree mount
5N8-23340-00-33 UNDER BRACKET COMP
Used on the following models
XJ650G/H/J/K - 1980 - 1983
XJ650LH - 1981
XJ750K - 1983
XJ750MK - 1983
1AA-23340-00-00 UNDER BRACKET
MAXIM - XJ700N/C/S/SC - 1985 - 1986
MAXIM X - XJ700XN/XNC/XS/XSC - 1985 - 1986
XV Lower triple tree mount
2AE-23340-30-00 UNDER BRACKET COMP.
VIRAGO 700 - XV700L/LC/N/NC/SS/SSC/CS/CSC/CT/CTC - 1984 - 1987
VIRAGO 750 - XV750U/UC/W/WC/A/AC/B/BC/D/DC/E/EC/F/FC/G/GC/H1/HC1/J1/JC1 - 1988 - 1997
VIRAGO 1000 - XV1000L/LC/N/NC - 1984 - 1985
VIRAGO 1100 - XV1100S/SC/T/TC/U/UC/W/WC/A/AC/B/BC/D/DC/E/EC/F/FC/G/GC/H/HC/J/JC - 1986 - 1997
VIRAGO 1100 SPECIAL - XV1100SH/SHC/SJ/SJC - 1996 - 1997
Return to “Fits 'n Bits; Yamaha...”
