Mikuni Carb Cables
Chucky
Mikuni Carb Cables
Post by Chucky » Wed Feb 10, 2010 4:52 pm
I found out today when running twin Mikuni VM30 carbs on a triumph; you can still use you're original 1:2 cable. Just Remove the main adjuster; this leaves independant adjusters on each cable after the splitter. :D
Happy days!
If you're running independant cables, your screwed as you can remove the adjusters.....sorry!
Chucky
Post by Chucky » Wed Feb 10, 2010 4:53 pm
Oh the reason being that while mikunis accept the same nipple size; they require a greater ammount of free play.
