brakes wont work
Chat about choppers here. Any posts considered by forum administrators to be used by businesses as unpaid advertising will be promptly removed...
jsalt
brakes wont work
Post by jsalt » Mon Feb 18, 2013 11:28 pm
Helo guys, changed brake fluid on back brakes, bleed them, but not getting any build up of preasure, its a hunter spyder, any ideas? Done the pump the brake and get no bubbles out nipole, just no preasure build up of any substans, any ideas? Do i take plunger apart have look? Am i pushing it down too much?
Jon
I hear voices and they have some good ideas!
Re: brakes wont work
Post by Prof » Mon Feb 18, 2013 11:32 pm
A bit of research suggests that initial pumping of master cylinder may have damaged the piston rubber if there was some corrosion in the section of the bore that is not swept under ormal use.
Probably need master cylinder kit, but need to lightly hone the bore before putting in new rubber.
I have a hone down here... if you want to use it and do the job down here give me a call.
Post by Bearcx » Tue Feb 19, 2013 9:38 am
Dont open bleed nipple too far, it only needs a quarter to half a turn open.
It roughly goes like this....
Fill master cyl,
Pump, pump, pump then hold lever down,
while holding down,
Crack open bleed nipple,
Pressure should squirt out,
Nip up brake nipple.
Release lever. Check fluid level.
Repeat
jsalt
Post by jsalt » Tue Feb 19, 2013 9:41 am
Took master apart, looks like new rubbers, took line off didn't really pump well still, will ring to see if their is even a kit for it, thank andrew
jsalt
Post by jsalt » Tue Feb 19, 2013 12:55 pm
Thanks for ya help guys, maybe opening to much ,will have another go sat probaly
Jon
jsalt
Post by jsalt » Sun Feb 24, 2013 10:03 am
Got it vacuum flushed,mates mate, seems to be working
Jon
Return to “Chopper Chat (includes how to post photos)”
