shocks to lower my virago 1000
dale619
Post by dale619 » Mon Oct 28, 2013 9:45 pm
hi is there anyone out there that can tell me what shocks I could use to lower my 1984 virago 1000 mine are around 12'' thanks
Re: shocks to lower my virago 1000
Post by Prof » Mon Oct 28, 2013 9:55 pm
Harley do an 11" shocker. It is fairly wide at the top and bottom so you'd need to measure one before you bought it If it will fit, get a sportster shock as it has a softer spring.
Alternatively pick up a 12" shocker that can be shortened. You will need to pull it apart, unscrew the top eye and shorten and rethread the shaft, then cut the spring and heat and squash the end so it ends up reduced the same amount as the shaft.
neale
Post by neale » Tue Oct 29, 2013 12:39 am
Harley shocks won't fit an XV1000 properly, you could probably get them to mount but you'd be asking for trouble.
You can buy shorter aftermarket shocks for the XV (Progressive is one brand that's fairly good, I have progressives on my XV at the moment, another brand is Hagon, I have a set that I haven't tried yet, but I've been hearing reports of the Hagons being dodgy), alternatively, if you aren't fussed about the ride, you can wind down the stock shocks to their stiffest setting, which will shorten them a bit (some say up to an inch, but I haven't tried that)
FWIW
Neale
Neale
Post by Prof » Tue Oct 29, 2013 8:39 pm
Here's a link to progressive site...
http://www.progressivesuspension.com/productsearch.aspx
I use Progressives for HD (previous post). Haven't ever checked to see if they do narrower ones... yes they do 11" to suit xv's as Neale said.
I just checked a new shocker from IKON I have that is the shortest they have and it is 12"
YSS shockers may be another option
Post by ol_750 » Wed Oct 30, 2013 6:52 am
Suzuki Savage LS650 are 10.5 inch eye to eye & fit straight on.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... SS:AU:3160
Post by Bearcx » Wed Oct 30, 2013 1:44 pm
Excellent stuff. :D
dale619
Post by dale619 » Wed Oct 30, 2013 1:50 pm
thanks heaps for all the help :)
dale619
Post by dale619 » Thu Oct 31, 2013 9:15 am
I went with them ls650 shocks thanks :)
wolfsbane
Interests: lots of stuff
Post by wolfsbane » Thu Oct 31, 2013 10:22 pm
dale how low is that going to take her ?
you mounting rear gaurd to swing arm ?
questions for my lol
Wassa - Goldy
Post by ol_750 » Fri Nov 01, 2013 6:02 am
wolfsbane wrote:dale how low is that going to take her ?
He'll have about 2" clearance between tyre & guard & will probable scrap on a good bump.
dale619
Post by dale619 » Fri Nov 01, 2013 12:19 pm
yep putting the fender to the swing arm I like the look when there close to the tyre il chopping off the back for a solo seat new bars forwards and paint job should look cool :)
Post by Silent Grey Fellow » Fri Nov 01, 2013 9:18 pm
Instead of changing your shocks you could use lowering blocks
dale619
Post by dale619 » Sat Nov 02, 2013 10:26 am
how do you use them ????
Post by ol_750 » Sat Nov 02, 2013 6:35 pm
dale619 wrote:how do you use them ????
Lowering bloocks will be tricky with the shaft drive.
When I get home on my PC I'll put a link to my bike build on hete
that shows the lowering block Xsesive did for my XJ900.
dale619
Post by dale619 » Sat Nov 02, 2013 7:39 pm
