Extended forks for Z900...
'To the point' advice on what fits what, parts interchangeability and simple solutions to common problems... This forum applies to Kawasakis. Keep your post brief. You may include 2-3 clear cropped photos (max 600 pixels wide)...
Post by Prof » Sun Jul 09, 2006 12:16 am
Inexpensive solution to 5-7" extended forks for 900 posted by chopaweeza...
Use the 36mm tubes out of an 80's KX, KLX or KLR kawasaki. I've done it to kawasaki front ends about 15 times over the last 20 years and they work as good as Franks. You use the tube & top cap of the Crosser , a tube spacer to fit on the top of the springs and the rest is the original bikes parts. Those different models are slightly different lengths and they give between 5" & 7" extra. Crosser tubes are usually about $50-80 and the tube spacers another $5-10 .
chopaweeza
Post by chopaweeza » Sun Jul 09, 2006 7:45 pm
It also works on Z650, Z750, Z1000 and Z1100 up til 1982. GPZ's with 37mm forks use RM125 tubes so on.
Post by Cromag » Mon Jul 10, 2006 9:10 am
reminded me, i rode a honda four...in a stock frame with big Z triple clamps and hangers, gave the wholeshebang a real nice stance and as it was the 80's a mag wheel.
Return to “Fits 'n Bits... Kawasaki...”
