22 Moulding #3...
22 Moulding #3...
Post by Prof » Mon Feb 26, 2007 2:16 am
Frame and swing arm moulding...
Steering head area was a real challenge to smooth with minimal putty. Lots of welded holes and grinder marks to be dealt with...
More work yet to be done...
Finished frame from the rear...
Welds cleaned up with angle grinder and flap disc prior to moulding. Flap disc was also used on many spots on frm to smooth out angle grinder marks rough spots on frame and rough welds etc
Areas like this are so much easier to keep clean once moulded...
Moulded swing arm...
Almost finished. Spent more time finishing tank after a day's rest as it had some irregularities from factory and moulding also needed more work. Then it was off off to see AJ about priming and painting...
