BearCX 500 Chopper build-up.
This one seems to have stalled.
Post by Neo Dutch » Fri Jul 17, 2009 7:54 pm
Post by pommychopper » Fri Jul 17, 2009 8:24 pm
Shocking welding on both of em! :(
Post by Bearcx » Sat Jul 18, 2009 6:30 am
Thats bad, real bad.
...and He reckons that one from Choppercharles, looks like crap!!!
Update soon. Got rim back from machine shop, final drive fitted, cut backbone to drop engine lower and stuff...
Pics coming.
Post by Bearcx » Sun Jul 19, 2009 7:36 pm
A couple of pics. Pie cut the backbone to lower engine, fitted ZXr6 to accept final drive, mocked up rear shocks, installed swing arm. Slowly getting there.
Post by Prof » Sun Jul 19, 2009 9:11 pm
great to see the progress Bear... looks good.
Post by pommychopper » Sun Jul 19, 2009 9:34 pm
I still wanna know how you're going to do the drive!!! :D
cjmeg
Post by cjmeg » Mon Jul 20, 2009 8:04 am
pommychopper wrote:I still wanna know how you're going to do the drive!!! :D
All sorted PC, so he tells me.
Motor moved over a little, drive is fitted to the ZX rim
I tell you, this guy is talented :D
This machine is a work of backyard art
Post by pommychopper » Mon Jul 20, 2009 5:55 pm
Darn it i need pics!!!! :D
Post by Bearcx » Mon Jul 20, 2009 9:41 pm
Easy Fella, you'll pop a vein.
Engine is right side shaft drive. Mounted the engine 25 mm over to the right, had a "boss" made to fit in the rim, and machined the boss down until the final drive (diff) was in line with the drive shaft and the tyre was centred with frame.
Rear subframe was widened 25mm each side, and swingarm stretched 75mm.
Cut made to backbone to lower engine height and get sump level.
Post by Bearcx » Mon Jul 20, 2009 10:03 pm
Some more. Sorry, not much of a photographer.
Need to make longer engine hangers, re-install rear shock brackets, weld small "disc" in backbone cut, should be finished in a day or 200.
Post by pommychopper » Mon Jul 20, 2009 10:06 pm
I'm liking what i'm seeing!!!
Good on ya bud! :D
Post by Cromag » Tue Jul 21, 2009 8:52 am
WoW! i dig the pic showing the fan up front...looks like its gonna take off!!!!
Man that bike sits so right, tell me youre not gonna put a big ugly tank on it, you need to show off the foundations on that beautifully unique chop
cjmeg
Post by cjmeg » Tue Jul 21, 2009 6:46 pm
Cromag wrote:Man that bike sits so right, tell me youre not gonna put a big ugly tank on it, you need to show off the foundations on that beautifully unique chop
No, the tank he has will mean someone else has a bike with a shorter range than my Vmax :shock:
Keep going, Bearman. Almost there!
Post by Bearcx » Tue Jul 21, 2009 8:40 pm
Thanks Guys,
It's taking way to long. So for the time being (and cost) I'll whack to CX Custom tank back on. Just so I can get it on the road.
Glen, I might get the same mileage as your Vmax, but my 50 HP wont keep up with yours.....
Mmmm.......a Vmax engine :twisted: :twisted: :twisted: :twisted: :twisted:
Post by Bearcx » Mon Jul 27, 2009 11:55 am
Pie cut frame, tacked on rear shock mounts, no seat, no bars.
More or less finished set up.
