77 Ruiner Shovel
ran
Re: 77 Ruiner Shovel
Post by ran » Sun Apr 08, 2012 2:29 pm
image upload
ok...had to do some wiring as she was shorting out, fitted small air filter as i hate those big s&s ones, need to clean up the bars...too much clutter..and make up jockey shift/ foot clutch...
Post by Brassy » Wed Apr 11, 2012 7:04 pm
drill holes in your bars and run the wiring internally, this will clean it up.
ran
Post by ran » Wed Jun 13, 2012 6:43 pm
picture hosting
been playing....jockey shift now too...
Post by El Skitzo » Thu Jun 14, 2012 10:03 am
Updated paint on the tank looks good 8)
ran
Post by ran » Thu Jun 14, 2012 10:12 am
cheers mate....got new bars coming, and whisky throttle, and am fitting some tiny switches so bars will be cleaned up...got to mae a spacer so i can get rid of the speedo cable from front wheel too
Post by Brassy » Thu Jun 14, 2012 6:10 pm
on some shovels you could also run the speedo from the tranny, if you still want a speedo that is !
Post by Prof » Fri Jun 15, 2012 9:48 am
FXwide Glide had the cable coming out of the front left hand side of the gear box. If your's is not an FXWG you will see a boss on the casing where it goes.
When I do my new front end I will run a bicycle speedo. They are cheap and pretty much indestructable, small and light and a single wire runs to a magnetic pickup that you can set up on front or rear (mine will be rear) wheel. They can then be claibrated to get them spot on. They do require a watch battery to power them and the more expensive ones have inbuilt illumination. A couple of the guys over hear just set up a small LED over them to provide noght time light.
Ideal way to go I think... no need to oil cables and grease speedo drive, no thick cable running to front wheel and no maintenance.
ran
Post by ran » Tue Jun 26, 2012 8:09 pm
fitted zombie bars....got some micros switches to fit now..and ill order a whisky throttle...
free image hosting
some cool shots a mate shot the other week....
picture hosting
photo hosting
Post by El Skitzo » Wed Jun 27, 2012 10:08 am
I saw some of those riding shots on the Church of Choppers blog this week. You're famous! :wink:
ran
Post by ran » Sun Jul 01, 2012 3:55 pm
lol...im so stoked to be on that blog.....thats where i learnt about Basara....and became inspired....its a bit of fun.....
ran
Post by ran » Fri Nov 02, 2012 1:12 pm
Aussiehard
Post by Aussiehard » Fri Nov 02, 2012 2:06 pm
Three CA bikes is a good start, Your two Ran and I bet that is Ollie's 750 in the back ground.
Lost the P-Pad, motor done, extended the pipes & drilled fishies, whiskey throttle, new rear fender with tail light, open belt primary, you been busy!
ran
Post by ran » Fri Nov 02, 2012 2:17 pm
that is Ollie's bike.....looks like some really cool bikes..Tim Kill has 2 at show that i fn love...
Aussiehard
Post by Aussiehard » Fri Nov 02, 2012 2:24 pm
Going away to Halls Gap tomorrow for our anniversary & Her B'day……...going to try and slip in to the show at opening time on the way, hoping she will let me. Don't want to do a 4hr+ drive with a grumpy Missus! Or I might deliberately drive in to a tree or off a cliff just for some peace.
