Battery Size Question
flexyourhead
Post by flexyourhead » Wed Oct 17, 2012 7:45 pm
It's time to get myself a new battery.
What I'm wondering is can I use a smaller sealed battery like ones found in security panels and fire panels? The ones I use in the fire industry are 12v7Ah and bigger. I'm thinking as I have no electric start on the bike and all I'm really running is the brake light, headlight, horn and coils/ignition side of things. I can't see any reason why the batteries we use in the fire industry aren't suitable.
Is there something I'm missing here?
If I was running the electric start, fair enough but as I'm not, I'm thinking they'd be fine.
Any input is appreciated.
Re: Battery Size Question
Post by Prof » Wed Oct 17, 2012 8:36 pm
Phil (xschop) should be able to answer this one. Send him a pm. 7ah would be fine with out electric start. The question I would have is whether they are ok being charged by a bike alternator at 14-15 volts.
flexyourhead
Post by flexyourhead » Wed Oct 17, 2012 8:47 pm
It shouldn't be a big issue. We run 2 x 12 in series on the fire panels. Their charge voltage is around 27.5 volts as a norm.
Am I correct in assuming the only reason to have a heavier duty battery would be because of the current draw with an electric start?
Post by Bearcx » Wed Oct 17, 2012 10:31 pm
Hans (Waterbottle) ran 2 dry cells out of emergency light systems we had, on his CX500. Ran fine for a year, electric start.
Soldered a joiner between the two.
Aussiehard
Post by Aussiehard » Thu Oct 18, 2012 10:08 am
There is the possibility of running a capacitor and no battery also.
