Electrics boxes?
Electrics boxes?
Post by Prof » Wed Jun 06, 2007 10:36 pm
Here are some water proof aluminium boxes I came across in Dick Smith's the other day. Could come in handy for putting in your smaller electrics. Alloy would polish up quite well...
The largest is 171mm x 121mm 55mm. The smallest is 115mm x 65mm x40mm
They also had some grey poly boxes the lagets being 220mm x 150mm x 55mm
74chopper
Post by 74chopper » Thu Jun 07, 2007 6:20 pm
i am using one of those at the moment, got it from a place called jaycar (see their website), works great, will post some pics soon.
Cheers Rob
750/4 choppers Rock
browder
Post by browder » Thu Jun 07, 2007 11:26 pm
i been searching the web for something like that state side to use on my sons xs haven't had any luck what kind of search should i do?
NEVER DOUBT YOUR DAWG !!
admin
Post by admin » Thu Jun 07, 2007 11:36 pm
G'day Browder,
You can find the Jacar products here...
http://www.jaycar.com.au
On the left under Browse Products, select 'Enclosures', then choose a sub category (try Aluminium to start with).
You should be able to find similar products in the US. Try an electronics supplier or search for enclosures.
Michael,
Site Admin...
www.ChoppersAustralia.com
('82 Sportster :P )
Post by Prof » Fri Jun 08, 2007 9:46 am
G'day Browder. If you can't find one over there at electronics shops, I'll pick one up for you and send it over.
browder
Post by browder » Fri Jun 08, 2007 11:01 pm
thanks fer the offer--i'm starting to find em now just a matter of time till i find the right one
Electrics boxes in use...
Post by Prof » Sun Jun 10, 2007 8:36 pm
Email from 74 chopper...
Here are some pix of the tandy boxes you posted on the site the other day, I got them from jaycar,
Case has ignition switch/headlight switch/tail light switch so I can have lights off when kick starting. At the back of it you can see 2 fuse holders. These are for the light fuses.
I have an inline "wedge" fuse holder inside the box screwed to the roof of it so the wiring comes out of the box when I take the lid off.
On the outside top of the lid is the solid state reg/rectifier in the wind to keep it cool.
The hole thing, box/switches/wiring/fuse holders and fuses cost around $70... looks better than my santee boxes, and is a hell of a lot more watertight.
Cheers, Rob...
