WIRING HELP WANTED
Gringo
WIRING HELP WANTED
Post by Gringo » Sun Jul 18, 2010 5:49 pm
I need help: having a problem with wiring on my K2 750 4 Honda. What we have done so far, all 5 alternator wires connected fine, alternator wires checked to make sure the yellows arent earthed, all good. Red/White connected to +12volt, green connected to - (earth), black connected switched to +12volt. All wiring done as per instructions on regulator rectifier installation.
Problem: When ignition turned on there is enough current drawn to trip 20 Amp Circuit Breaker. If Black wire (switched +12volt) is disconnected it doesnt happen.
Can anyone tell me WHY and how to Fix?????????
Regards, Gringo.
Id rather be bobbed
Post by KeithinSB » Mon Jul 19, 2010 1:41 am
Hi Greg-0,
I think your white wire needs to go to the "F" terminal on the regulator, not to battery +.
Here is a simple wire diagram.
Good luck!
Keith
Gringo
WIRING HELP WANTED
Post by Gringo » Mon Jul 19, 2010 4:17 pm
Thanks Keith, I am using an intergrated regulator / rectifier not standard seperate units regards Gringo
Id rather be bobbed
Post by KeithinSB » Tue Jul 20, 2010 1:51 am
the white wire is the field wire. it turns the alternator on and off.
It should be connected to the reg/rec somehow.
I could be wrong but I don't think it should be connected to 12v +.
Try disconnecting the white wire and see if the breaker still blows.
Cool to see you back around here Gringo!
Never seen you after Colac.....
Ever figure out what happend?
Cheers!
Keith
Re: WIRING HELP WANTED
Post by KeithinSB » Tue Jul 20, 2010 1:55 am
Gringo wrote:Thanks Keith, I am using an intergrated regulator / rectifier not standard seperate units regards Gringo
Like these?
http://www.oregonmotorcycleparts.com/Reg_rec_units.html
scroll down to the bottom of the page.
Post by Prof » Tue Jul 20, 2010 9:50 am
I've put this link on our links webpage... does everyone realise we have an extensive links page? It is regularly updated.
