10mm banjo bolt with brake switch
A place to list any choppers and related items you find on EBay, for general information and discussion re value, bidding etc
Post by dg6oo2 » Wed Sep 29, 2010 10:42 am
Found these on the ebay, - 10 mm banjo brake bolts with intergrated brake switch $23.oo buy now with $6.00 delivery, item number - 140368028008 i,m gunna get two myself and test them on the ft 500 .
MArki
Post by MArki » Fri Oct 01, 2010 10:11 am
I've got em on the chop... they go alright.... easy as to wire up..
the only think i'm gonna say is becareful when you get them... sometimes the wires are exposed past the potting on the switch body end... not so good to weathering. ive had to return a couple for this reason.
Also some bikes have a course and fine thread....
IE.. i'm using a GS1000 rear master... and it wont fit... however it will into a CB front master.
so just be careful on that one.. and you'll be right!
Post by dg6oo2 » Wed Oct 13, 2010 7:00 am
Thanks for the heads up on the switches one is going on the hacked ft 500 thats waiting to be finished .
Return to “Items on EBay...”
