ADR's
ADR's
Post by Prof » Tue May 27, 2008 6:41 pm
We regularly get questions re adr's and replies with links...
Could someone (or everyone) please find copy and paste the different links that have been put onto these forums onto this thread, so we have them al in one place for easy reference. If this can be done would be a great help...
cjmeg
Post by cjmeg » Tue May 27, 2008 7:56 pm
National code of practice for trikes..
http://www.infrastructure.gov.au/roads/ ... eb2006.pdf
Post by pommychopper » Tue May 27, 2008 8:33 pm
National Code of Practice for Light vehicles including Bikes and Trikes
Post by pommychopper » Tue May 27, 2008 8:52 pm
ADR's SA...
Post by Prof » Fri Jul 30, 2010 9:00 am
Posted this elsewhere, thought it should go here too...
In SA ADR's were adopted in 61. But all bikes in SA except some of the very vintage stuff, are obliged to conform to a basic set of standards including 550 rule, central mounted taillight, a reflector, brake on each wheel, rear chain guarded up to 300mm from rear most peg, pillion pegs if a pillion seat, high low beam, horn. Number plate must be illuminated. Post 88 have some more requirements (mainly noise). Post 91 need indicators. Pre 75 need only one mirror. Post 34 need a stop light.
all hydraulic brake lines mus t have permanent ID markings
All bikes must be fitted with two mudguards that " catch or deflect downwards any stones, mud, water or other material which may be thrown up by the roatation of the wheels). How this is judged in practice I am not sure, but to be safe a gurad/numberplate that covers the rear wheel vertically seems the safe bet. Rear guards on cars need to finish at 45 degrees as measured from axle, so it could be argued that this si satisfactory for bike rear guards as well.
handle bars... Pre 88... lowest part of hand grip must less than 380mm above attachment point to motorcycle;
Post 88... Lowest part of handgrip must be less than 380mm above lowest part of upper surface of riders seat.
Max handle bar width for all bikes is 900mm
Noise levels... pre 85 100 decibels. Post 85 94 decibels. I watched a vehicle being noise tested by a local engineer recently. Vehicle had to drive by at 60kph and tester was set about 15m from vehicles path.
This information taken from the latest information bulletin (bulletin 6) this is what is received form Regency when enquiries are made as to what a person can and can't do to a bike. If you are modifying your bike, call the Motor Reg in your state and ask for this information telling them the year of your bike.
Adr's go into intricate detail including braking distances etc, but the above is what they send us, so presumably what we need to comply with.
Post 98 (ADR57/00) rules are much stricter and require operation of indicator/horn/high/low buttons with hand on grip, idiot lights must be labelled, foot change must be on left, self closing throttle, E marked lights.
I can find nothing in regs about welded handlebars.
sharky
Post by sharky » Fri Jul 30, 2010 4:16 pm
NCOP8 Section LL. 2.2
'The heating or welding of steering components will only be accepted if the modification in question is accompanied by a satisfactory report from a Signatory or Metallurgist.'
This will be applied to handlebars according to engineer.
I was lucky and found the Moto Guzzi Bellagio 2007 has 1 1/4" T bars that are 22mm at the ends for switch gear and it is an ADR compliant bike.
So a set of 1 1/4" harley bars, sleeved, welded and powdercoated and Bingo.....bellagio bars mr engineer...honest...
Jesus died for his own sins.....Not mine.
NSW regulations for motorcycles
Post by Prof » Wed Sep 29, 2010 8:55 pm
ADR re sticker on exhaust
Post by ol_750 » Thu Sep 30, 2010 10:29 am
RTA guide lines...
This bit of legislation was acually repealed in NSW
Will post details of this asap
Motorcycles manufactured from 1st July 1988 have all components of the Silencing System marked
with the name or trade name of the manufacturer. Every motorcycle carries information of the Stationary
Noise Test in the following format:
STATIONARY NOISE TEST INFORMATION
Tested at............. dB(A) at........... r/min
Silencing System: (manufacturer’s name)
Identification : (trade description)
ANY REPLACEMENT PART OF THE EXHAUST SYSTEM MUST
SHOW THE TRADEMARK OR THE NAME OF THE ORIGINAL
MANUFACTURER OF THE SYSTEM.
Detail of the Repeal of Exhaust label (NSW)
Post by ol_750 » Thu Sep 30, 2010 7:10 pm
Post by Prof » Thu Sep 30, 2010 11:33 pm
thanks a lot ol750. I read this one on NSW regs and was quite dismayed.
NSW Regs
Post by ol_750 » Fri Oct 01, 2010 6:16 am
Yeah Prof they dont give you much room to move on a standard bike unless you have the time & money to go an engineered bike.
I'm still reading & trying to make sense of the EPA's driveby instructions for the noise levels tests.
Cheers Andrew B
Re: ADR's
Post by Prof » Wed Jan 11, 2012 10:57 am
transfered form another thread...
Here is a link to some of the ADRs
http://theflyingxs.blogspot.com/2011/08 ... -aust.html
Dunny
Re: ADR's
Post by Dunny » Wed Sep 05, 2012 7:10 pm
Here is the list of applicable ADR'S for 'L' class vehicles
http://www.infrastructure.gov.au/roads/ ... _Group.pdf
In addition I have two NCoP for LL (motorcycle) & Lo (trikes) & one NCoP that contains a check list for LO & ICV Vehicles on file that I can Email if any one wants to bang their head on the wall for an hour or two.
Not only is the universe stranger than we imagine, it is stranger than we can imagine. ... Sir Arthur Eddington
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
Mark Twain
Dunny
Re: ADR's
Post by Dunny » Thu Sep 06, 2012 12:04 pm
Some links
ADR # 43/04: Vehicle Configuration & Dimensions
http://www.comlaw.gov.au/Details/F2006L01430
ADR # 57/00: Special requirements for L group vehicles
http://www.comlaw.gov.au/Series/F2006L02301
ADR # 83/00: External Noise
http://www.comlaw.gov.au/Series/F2005L03523
ADR # 42/04: General Safety Requirements
http://www.comlaw.gov.au/Details/F2011C00102
Mark Twain
Re: ADR's
Post by Bearcx » Fri Aug 30, 2013 7:04 pm
Noise emmissions ADR's. Not sure if these are on here. (2006)
Bikes / Cars / Diesels / etc....
http://www.ntc.gov.au/filemedia/Reports ... pt2006.pdf
