Back on the job Tuesday and finished the project at 6.45pm; total of 13 hours...
Reinforcing tube welded in. Vertical support is part of original tank front mount. Helps prevent the curved tube from flexing. Flame will be moved an joined (on a tip) further forwards to help further stabilize the tube...
Now to permanently install the replacement top tube piece. I will slug the join for to produce as much rigidity as possible for this area. Slug is a piece of hollow bar that needs very slight machining to fit inside the backbone. Standard practice is for slug length within each piece of tube to be a minimum of 1.5 times the ID of the existing tubes...
Slug machined. To fit it, requires the slug to be fully inserted in the short tube, which is then slid into place and the slug moved forwards.Both pieces of backbone therefor need to be slotted...
Slug tapped into place using a drift punch. Short section of backbone is now welded at join (plus slot welded in ) and at steering head...
Existing backbone is not sufficiently strong for such a heavy and powerful chopper, especially with such a high and out front steering head. It is now to be 'plated' with a tube that fits snugly over it. Unfortunately I had to buy a full length of pipe(6M) to get the right size piece (800mm). Looks like I'll be doing a bit of overkill on the backbones of future choppers as it is a bit larger than I normally use. Here Peter is splitting the tube in half. To hold it in the vice a piece of pipe is slipped into one end. A tight fit which was just the ticket...
Checking backbone for straightness...
First step is to fit each half to the steering head. Side sits back 15mm from steering head so that is how much will need to be relieved on top (see texta mark)...
Halves have to be notched and relieved along their lower edges to clear engine mounts etc...
Takes a lot of trips to linisher and grinder to get them right, as we don't want any big gaps to fill. Check for straightness of backbone as tube has a bit of a gap at the rear. It's straight, so check our larger tube half...
When tube is split it often is under tension and curves slightly as did this one. A couple of gentle nudges (one was too far) on the press gets it fitting nicely. Sleeves will be welded down each edge and at half a dozen places along the sides (plug welds) so needs to fit. Any gaps at the welds will put things under tension and could pull the frame out of alignment.
We have not set this frame up with plumbob and laser; 1. to keep time down, 2. Because steering head has simply been pushed straight ahead without cutting the down tubes, so if we are careful, it will stay in alignment...
Both halves welded and plugwelded. This is done slowly and in short welds keeping in mind a long weld or groups of welds along one side without alternating with the other, WILL pull the tube our of alignment. Welding is spread out over an hour to let things cool and stay straight...
Flames are cut off and the paint removed. A 25mm piece of 4mm is shaped (wide strip at bottom of photo) and welded on to the flames...
Here fitted. This has moved the flames rearwards so one tip can be welded to the curved tube (white arrow). This is not a major support, but will hopefully provide just a little extra rigidity. Cardboard pattern made for other piece of filler...
Welded in a the tank set up...
Tank bracket is now welded back in place...
Just one little piece needed to finish flames off nicely...
How do you hold something this small and weld with out burning your fingers? Just tack on a long piece of scrap as a handle. Break it off when the piece is welded in...
Job done. Steering head deraked slightly combined with dropped forks keeps us 10mm within the Ridikulus Rool...
6.45pm and time for Peter to get home which is over an hour away and he doesn't want his car to be roo bait.
Chopper loaded and ready to have some tidying filler and then paint. It'll be on the road soon so keep your eyes peeled. Not my style, but Peter loves the big motor and rear suspension for longer trips something his classic CB750 is lacking...
So it's buyer beware. Big, heavy, powerful choppers need strong frames especially around the steering head. I shudder at the flimsiness and lack of gussetting I see on many of the modern Long Bikes. This one was definitely a prime example. Cracked around 3/4 of the backbones diameter, made this chopper a potentially serious accident waiting to happen. If that frame gave way on a bumpy left hander at speed and put the rider into an oncoming vehicle... I shudder to think about it.
If you are buying a custom frame, make sure it is well gusseted and strong before yo paint it. Better an extra $800 worth of prevention now than the consequences of an accident in the future. If you aren't sure, ask someone with qualifications or experience.
Safe chopper riding folks!
