THE CHOPPER SHED INDEX
Post by Prof » Fri Aug 01, 2014 12:50 am
This is the beginning of a complete index of TCS posts... please be patient it will take time...
001 Bazzas Triumph... 1 page (incomplete), forward control brackets, rear engine mounts, backbone replacement, sprung saddle base and padding and a few other bits
http://www.choppersaustralia.com/forum/ ... f=60&t=102
002 Cable brake construction... 1 page
http://www.choppersaustralia.com/forum/ ... ?f=60&t=48
003 Brian's rear mudguard rebuild... 1 page, Inexpensive rear guard, stainless sissy bar
http://www.choppersaustralia.com/forum/ ... =60&t=2543
004 Paul's CB500 rebuild... one photo & brief explanation
http://www.choppersaustralia.com/forum/ ... =60&t=3502
005 Brackets etc... 1post and two photos (oil tank brackets, exhaust brackets, with a brief explanation
http://www.choppersaustralia.com/forum/ ... =60&t=4175
006 Sissy Bars... photos and brief explanation on 6 different sissy bars and different ways of mounting
http://www.choppersaustralia.com/forum/ ... =60&t=4197
007 Forward Controls... 1 post with photos and comments on a set of chromed forwards for an 82 Sporty
http://www.choppersaustralia.com/forum/ ... =60&t=4200
008 June, Seat, slugs & lowering blocks... Seat base and foam for a 1500 cruiser, stainless fork slugs, lowering blocks for an 80's Suzuki, brief explanations
http://www.choppersaustralia.com/forum/ ... =60&t=5122
009 Steve's Yellow & Black CB750... 3 posts forward controls, rear guard, novel place for ignition switch, detailed fabrication of stainless 4 into 2 exhaust system
http://www.choppersaustralia.com/forum/ ... 232#p35232
010 Trident, seat, forwards, pipes, electrics box, brake.... One post with pics of each finished job. Brakes show how to set up rear brake plate meant for swing arm onto a hard tail. Also unique but very comfy 'camel's hump' solo seat
http://www.choppersaustralia.com/forum/ ... =60&t=5107
011 Sidestand... Stainless sidestand with a snakes head, final pic
http://www.choppersaustralia.com/forum/ ... =60&t=5288
012-116 BensVF750... This 5 part series of posts is a very detailed account of the complete build. New rear sub frame, unique tank and electrics box. Link to next part at end of each part...
http://www.choppersaustralia.com/forum/ ... =60&t=5358
017 Budget Tail light... Using an old bicycle headlight and an aftermarket trail bike taillight into a one-of-a-kind chopper taillight. Bunch of pics and explanation
http://www.choppersaustralia.com/forum/ ... 876#p36876
018 Slugs... a couple of pics of different slugs I've made with a few comments about safety
http://www.choppersaustralia.com/forum/ ... 805#p36805
019 1975 CB750 progression... See a CB750 raked and back on the road in 1.5 days! Lots of photos and a full explanation, plus other bits and pieces
http://www.choppersaustralia.com/forum/ ... 750#p37750
020 Scouser's T140 V... This Triumph was a disaster when we got it. Engine needed everything inside new. Engine was badly misaligned in the frame. Frame was too long etc. This series of posts and more in a different section of the forums shows major changes done (some in detail) in The Chopper Shed and some done a year later by the owner. Interesting to see the difference shortening a long rigid frame makes. Also interesting tail light treatment.
http://www.choppersaustralia.com/forum/ ... =60&t=5336
021 Prof's model U 1974... Five photos of chopper Prof took 2 years building 1972-1974 with a list of work done.
http://www.choppersaustralia.com/forum/ ... 461#p38461
022 Aug 2009: Rake & Lower, 73 CB500, 95 Virago, 81 XV, XS65... A couple of posts. Close up photos of extending the neck of an XV/Virago, lowering the rear of an XV (single shock). Before and after shots of CB550, XS650, XV and Virago lowered and raked. Plus some sissy bar ideas.
http://www.choppersaustralia.com/forum/ ... =60&t=4169
023 Chops /frames, Shakey & Pygmy's Hondas, GS850, 82 Sporty... Before and after photos of a full chop job on an 82 sporty. A couple of pics of a SOHC CB750 frame rake. A couple of pics of a new rear sub frame of a GS850 and a fully damped sprung saddle. An explanation of the mechanics of sprung solo saddles. Top tube repair on CB rigid frame. Cool way to mount a chain guard. Steering lock lug. Close up shots of front and rear of CB cable operated drum brake setup and finally a trick saddle that doesn't look sprung.
http://www.choppersaustralia.com/forum/ ... 199#p27671
024 You won't believe this.... Bobs Honda Chopper... Some interesting info on springer function/malfunction. How to renew the cork on a petrol/oil cap. Making a vent out of a bolt. Underneath shot of an inner sprung solo saddle.
http://www.choppersaustralia.com/forum/ ... =60&t=5983
