Vf750 Sabre - with a cafe orientation
Rayman
Post by Rayman »
Figured I should put this up here as well .
Gumtree listing here ..
http://www.gumtree.com.au/s-ad/aberfoyl ... 1095905369
1982 VF 750 Sabre - with parts to return to stock.
Everything was gone through a couple of years ago - then the tank developed a leak.
Recently repaired tank and checked everything - and got her runnin again.
Engine has been checked - cams, tensioners and valve clearances all good.
Igntion recently gone through, replaced pulsers and renovated igniters, checked coils.
freshly rebuilt carbs fitted.
Has CBR 900 based rear shock upgrade fitted.
improved oiling mods done.
Original headlight set, instruments (working), indicators and bars come with it.
Original bars are approx 5" higher than the clipons shown fitted - if needed for back preservation / long distances.
Was over the standard old 80s instruments and square headlight - so new dash, temp gauge, clipons and dominator headlamps fitted.
If your looking for that big gutsy different Cafe racer - then here it is !
V4 not a vtwin -
front tyre 80%
rear due to be replaced -
Currently painted in gloss white - I call her Stormtrooper
If you want to check out my experience with these bikes -
check http://www.rae-san.com
currently working on
modded cx500 - untertail exhaust + lots of changes
VF750f - restoring a basket case very nearly there
vf750S - just needs the paintwork done and some tyres
gathering parts for - moto guzzi bellagio lookalike
version based on cx500
others
cm250
Re: Vf750 Sabre - with a cafe orientation
Post by Bearcx »
Very nice Ray, glad to see you're still messing with 2 wheeled stuff. Bear.
