My current builds
CA members' and friends' choppers... Discuss and show off your chopper here. Send your photos and description to our email address
Lenny88
Interests: Building and riding my bikes
My current builds
Post by Lenny88 » Sun Apr 15, 2018 12:56 am
Hi everyone, here are my 2 current builds.
First up is my 01 fxst that my old man owned, he built a 103 stroker with big cams, ported heads and a mikuni flatslide to name a few bits.
I've redone the bodywork in black with a copper and gold flake, reshaped the seat, tank lift, lowered 2 inches at the back, internal bar wiring, new pipes debaffled and making a stainless steel 650mm long sissy bar.
Next up are 4inch over forks and possibly 5 degree triples.
I've also just started a rigid 750four build it started as a spare frame that sat around the yard at dads for 20 years. I'm using a tc bro's universal weld on kit to get it just how I want it.
I'm hoping to stretch the frame 2 inch up at the front and increase rake by 5 degrees, no stretch at the back and keep her nice and low! 4inch over tubes are also the plan.
Mechanically twin carbs will be going on, simplified wiring and dyna s ignition as it's been great on my current cb750.
Re: My current builds
Post by Prof » Mon Apr 16, 2018 10:11 am
The softie has quite a nice stance. You can get 3 degree raked fork bearing cups which will give you true rake. Raked triple trees reduce trail and therefor steering stability drastically especially with only 4" overs... only beneficial when going over 45 degree rake and 10" + overs.
See here for more of an explanation... http://www.choppersaustralia.com/defini ... uipment...
I have put 3 degree cups on a number of choppers and run a set on mine.
Lenny88
Post by Lenny88 » Mon Apr 16, 2018 9:13 pm
Cheers for the advice mate, I want to keep it rideable as I ride down to Gambier every September.
Post by El Skitzo » Tue Apr 17, 2018 10:35 am
I like where that Kwaka is going, keep up the good work
Lenny88
Post by Lenny88 » Thu Apr 26, 2018 7:41 pm
Well the frame is all welded up, a couple of braces will be going in once the the new rear fender arrives. What have other people done for forward controls on cb750 given the girth of the motor haha.
Post by Prof » Fri Apr 27, 2018 2:43 pm
Forwards, i do them normal height and usually mount off engine mounting area... have a look at The Chopper Shed forum and you will see a few I have done. Feet are out a bit wide but not as bad as the GSX Suzukis.
Post by TriNortchopz » Sun Jun 03, 2018 11:58 pm
Here is how i did forwards on my KZ 1000 in a Santee softail frame:
Lenny88
Post by Lenny88 » Sat Jul 20, 2019 8:04 am
Hey everyone, a long time between posts but a lot has been done. The rigid was finished late last year and now I'm onto the softail, currently rolling on 4"over tubes up front and lowered 2 down the back.
I'm looking to trade my stretched tank for a king sporty tank or something around 3.5gal in size if anyone is keen?
Post by El Skitzo » Mon Jul 22, 2019 9:28 am
The rigid looks great, well done!
Post by Prof » Sun Aug 04, 2019 11:02 am
750 looks like a well ridden chopper... bit cramped? Looks like a 500 tank on it.
Lenny88
Post by Lenny88 » Fri Aug 09, 2019 11:19 pm
It's not as laid back as the softail but a much easier riding position for darting in and out of traffic.
The tank is off a kwaka 440ltd
Post by Prof » Tue Aug 27, 2019 8:20 pm
Just looking at your CB again. Rear brake arm should be perpendicular to brake rod when applied hard, so that at rest it is rear of perpendicular. I assume arm is on incorrectly and you will need to lengthen your brake rod. Also check that your brake linings are thick enough. Most car brake specialists should be able to bond new linings to your shoes if the existing ones are too thin.
Return to “Your Chopper Pics”
