Mounting the fuel tank...
We are using the stock tank because Garry will be travelling longish distances (He lives 200 miles from civilisation!) and because it is actually quite a good proportioned tank. We are making some changes though; front will be raised about 3", cowl that covers filler and fuel gauge areas will have its front and rear extensions cut off. This will require an extra mounting point installed in tank. Tank will be moulded to cover joins that were hidden by the cowl extensions.
Anyway, to do all this requires new front and rear mounts. Usually when I raise a tank I am able to increase fuel storage by dropping the tunnel. However, Garry reckons it holds enough now and the extra cost would not be justified.
Old mounts are cut off and we begin setting up the rear mount, made of 3mm thick flat bar...
Needs to be folded. Here establishing the angle of the fold...
Folding can be done with a hammer in the vice in my cool old folder...
The tank's tunnel is wider than our backbone, so the mount is cut to clear backbone and fill in the gaps on each side...
Block of wood supports the bracket which would otherwise slip in the vice...
Before any heat gets near a fuel tank, it is essential to ensure there are no fumes left inside. Even if a tank has been empty for a while, fumes can be released from between any metal joins inside. A tank blowing up in your face can be fatal so unless you are highly insured and have a death wish, best be safe rather than sorry.
1. wash out tank with detergent and water. If is has fuel residue inside (or light rust), chuck some gravel in with the water and shake vigorously. Make sure you can get the gravel out though!
2.You can fill the tank with water prior to welding so all the inner space is taken up by water and there is no space for expanding fumes or you can blow it out with compressed air s you see here and then...
3. I prefer to prepare the tank further by filling in with carbon monoxide... and the shovel is a great producer of the stuff...
4. Now one final precautionary act. Put the tank behind a solid surface (steel door in my case), light the oxy torch and poke it near the hole. If you've don the job properly nothing will happen. If you haven't and there are still fuel residues or vapours you will enjoy various degrees of noise and flame!!!!
Back mount welded in . If there are gaps to be filled and or the metal is very thin, I use bronze rod. Modern tanks are VERY thin so take care...
Wooden block sets the tank at the right height...
Mount/filler is again made from 3mm steel plate. Part of the original mounting bracket is still attached to the tunnel and we will weld to this...
Hole drilled in mount and filler section curved to match tank curve...
As mount is tacked in place a ruler is run across high points (white arrows) at front of tank. This prevents any part of it protruding or sitting too far in and requiring excess bog...
I am going to weld a second but smaller piece of 3mm flat bar over the mounting bracket and part way up the filler section. Tab is cleaned off and a thin layer of bronze laid on it. Then using plenty of heat we will weld in the extra piece. If we produce enough heat the two pieces making up the tab will weld together all the way through. You can see the finished tab in a later pic...
The hole is redrilled after welding as some of the bronze protrudes into the hole...
Tank now put in place and rear mounting point marked. Then checked for centre...
A smallish hole is drilled first and then the correct size drilled. As we drill we check for centre as drill bits like to wander. Drill can be angled to correct any error. Here final check...
Meantime the threaded bungs are machined. Threads are 3/8" UNF . Red arrow shows the initial 10mm drilled to 3/8". Rest is drilled to suit the UNF tap. This ensures the mounting bolt can never be cross threaded...
Steel around hole in backbone is brought to red heat a couple of times and tapped in with a ball pene hammer. This allows me to have a thin lip on the threaded bung that will not protrude above the top of the backbone...
Bung tapped in...
Ruler used to check that it does not protrude...
A long bolt is screwed into the bung so we can use a set square to keep the bung square as it is welded...
In both planes...
Job done. Once again , bronze easiest way to do this...
Tank will be rubber mounted on 3mm rubber. These HD's do not vibrate like the older shovels and panheads, so the rubber can be thin. When bike is finally assembled, I will machine up a cupped stainless washer to contain a rubber washer for the top...
Now for the front...
Same procedure for the front hole. Here you can see hole being checked before it is fully drilled so drill can be angled if it is off centre...
Heated and tapped in...
Bung welded in the same as for the rear bung...
Once again, gaps need filling each side. Bunring off paint...
Left side needs relief for the wiring loom. Wiring look has plastic covers stripped off. Two lots of wiring each with their own plastic cover makes for a massive ugly mess. Combining the wires in one loom which will have one thin cover (I manage so remove 3 doubled up wires) will make this a bit more of a righteous chop, despite regs requiring total idiot proofing switch condominiums on the handle bars!!!!
Fillers welded in on both sides and some final detailed filling done with bronze to match the curved edges of the square backbone...
Well there it is. A strongly and neatly mounted tank. Next dent knocking and tidying up and mounting the cowl on top of the tank...
